Ok I’ve had programs crash on me, sure it sucks but we all get over it.
We get over the lost work too, well, we have to.
But this is a whole different thing alltogether!!
I’ve been working on a model in zbrush for a few days now, multiple subtools, 25mil total polys, 5 mil on the subtool I’m working on and everthing else set to the lowest subd level, it’s all fairly smooth so far. But today I tried to import an alpha, one I had imported and used before BTW, and zbrush locked up my computer, after about 30 secs, it seems to have recovered but gave me an unable to import file error.
And I go to check the file, guess what I find (or not find), my 2nd harddrive which all my work resides on has disappeared! (That’s what that sound was!! the same sound you get when a usb device is disconnected)
So I save what I have opened in zb to another drive and restart.
Sure enough the HD is back and all the files are fine, but the saved file from after the disconnect is un-openable, it just says not enough memory and crashes zbrush.
I was able to replicate this behavior too!
Has anyone else had this problem???
p.s: I’m using zbrush 3.1 on a AMD athlon am2 4000 computer with 4g of ddrii 800 hmz ram running windows xp 32bit
And I saved using the Svengali quicksave plugin.
I had been using this plugin’s Incremental tool save feature for a few days without problem.
But all the files I saved using it today, before and after the HD disconnect, are un-openable.
p.p.s WHAT THE FCKKKKKKKKKKKKKKKKKKKKKKKKKKKK
