Move gizmo reseting
hey folks, having a problem. I load in an obj and basically i just want to position in on the canvas, rotate it scale it ect and then place down some more shapes. When i import it and draw it on the canvas it sits inside the canvas so i just drag over the canvas with the move gizmo to bring it forward, but then if i try move it, it resets its position and rotation. is this normal? how can i fix this?
Just make sure to click and drag the gray circle when moving. Don’t click inside the gyro.
nevermind i worked it out, i was trying to move the object by using blank area inside the gyro, which meant it was snapping the object to the pixols underneath. I need to read more!
Similar problem, but can anyone help me out? is there a shortcut for duplicating objects? say if i position something on the canvas, can i then duplicate and move?
Transform>Snapshot or Shift+S.
Thankyou SOOO much!!
New question tho hahaha, im drawing using the deco brush so im using an alpha. When I draw though its transparent unless i choose black as the colour. Is there anyway to make it not transparent? so I can choose grey as the colour and not be transparent?
Would you like to know my hourly rate? :wink:
I’m not sure how you are getting the results you describe. To use the Deco brush:
  1. Click on the Current Texture thumbnail and select Texture Off to draw with color.
  2. To paint onto any empty canvas make sure ZAdd is on. Rgb or Mrgb must be on to paint color.
  3. Rgb Intensity will affect the amount of color applied.
HTH,
haha sorry bout pestering u mate :stuck_out_tongue: it’s a huge help though!
and I figured it out, it seems my image still had depth information, I didn’t flatten it so to speak. Fixed now though haha thanks again!
