Good morning,
I’v been working on a whole human anatomy study. I’m currently working on the hand and it’s almost finish now… I just need to finetune it. Here’s a pic:
Question, comment and suggestion are more than welcome!!!
Excellent modelling!
A couple of crits though:
The palm of the hand looks a little flat;
It may be due to the render, but the shadows on the fingers make them look a little bit square - the render seems to have a slightly ‘toon’ apperarence.
Also, the nails appear a little bit flat too.
These may all be down to the render, but if not, then they will improve the realism if you address these issues.
It’s still WAY better than I could do, so keep it up!
Jit.
nice job!
and really interesting render… mind to share some tricks or the material ?
keep it up!
Hey! Here’s an update on the hand and some pic of the full upperbody.
I changed a bit the hand, because at first I was using bumpmaps to add details but now it’s only geometry. Q & C are welcome!
DktrHeadache: The material I used is a tweaked version of Antopus clay material.
Hey JR,
Cheers,
Nate Nesler
Very nice work and presentation.
Really fantastic job! Is he skinless? And does he have a lowerbody?
really sweet!
i also like the shader, the cavity settings are really helping to define your musclature lines very well…
Thanks all! Lower body coming soon…
Poisonsoul: I agree, however I don’t know if the cavity shader is gonna be that pronounced in the final version.
Womball: No he is not skinless, thought I can easily figure out why you are asking. Let’s say it’s stylized realism, that’s why there are so much muscles, it helps learn them too…
MatrixNAN: oh yeah! You’re doing one too! It’s really a good exercise isn’t it?
Keep it up man! Well done!
ok, I modelled the upper legs here it is!
what do you guys think? Lower legs coming soon…
Looks pretty good, although the shader may be making seem lumpier than it is. I have to make my attachments that clear.
top quality render
what amaze me most is the render…it looks like some sort of toonline on top of SSS…in any case
its amazing
Very Nice model, and interesting render. Looks like you used a toon shader. I would like to know you did it, it looks ace.
i just think your work is VERY suitable for me to learn male anatomy. that’s your goal, right? i think i should print them out and paste them on my wall, so i would make less mistakes while modelling human body.
btw, do you have the plan to make a female one? i can imagine the female anatomy from this male one, but i dont think that will be precise.
and one more question, how did you get this render effect just like you painted it out. Pure Zbrush Render? can you show the most important parameters of the skin shader?
with tons of respect
What can I say? I agree with lek1 and ashaiad.
Wonderful anatomical study.
Your using Jack Petrocs DVD for reference? The model has the same starter pose as the DVD one. And also it looks similar like you were at least influenced by it.
i love the shader… can you give me it?
Thanks for all those positives comments guys!
So… since everybody seems to like the render style and want to know more about it, I joined to this post the Material and the Lights of my scenes. Take note that the base of the material is actually Antropus Clay shader that I’ve modified. Also keep in mind I play a bit with the colors and contrast in Photoshop with the Zbrush render.
Womball: I saw Zack Petrov DVD a couple of months ago, so I was actually influced by the starting pose and by the way he did the geometry in Maya. I did the same way. However for the sculpting, my main references are Burne Hogarth books and some pictures from www.freedom-of-teach.com to get more accurate references.
Lek1:Thanks man, If you actually considering using my images as anatomical references, be awared that they are not a 100% accurate, I did some stylization here and there…
For the female model question…hmmm…I don’t know yet, we’ll see…I don’t know what else to say!
Thanks again everybody, and stay tuned to see the final model!
The lower legs are almost done, so only the feet left to be done…
Alright, here’s the final model, I’m satisfied with the result, but still am pretty open to comments and critics…So, here it is! What do you guys think?
The feet look too puffy and not quite skeletal enough. Feet don’t have much muscles on them. Also your lacking the arches in the feet. The toes don’t jut out either, they tend to be 2 part bones that form a downward angle. The big toe angles slightly up though so its an exception. It does look like a Burne Hogarth’s studys too. Just not with that huge nose he draws all the time.
