I am having an issue where “Load a Font File from Disk” doesn’t work at all. I can select the font from the finder window, but when I open it, it doesn’t do anything. No font gets loaded. I’ve tried it with .otf and .ttf files and all have the same results. it is the first time I have tried to use this plugin.
I am running ZBrush 2019.1.2 on a 2019 iMac with the i9 and 64 gigs of memory. My OS is the most current version of Mojave.
UPDATE: I tried installing the fonts I want to use into Font Book. The installed fonts don’t show up in ZBrush either. I’ve been trying different fonts to see if it was a problem with particular fonts but so far no font outside of the system fonts will work in ZBrush.
