Interfaz troubles
Hi everyone! I’ve been watching some tutorials and there are some tools that I can’t use or they’re just not where they were suppose to be. This is how it looks:
The ones I’ve realized so far are: Edit mode, the “S” shaped tool in tools menu and the “Import” button in Draw/front-back/map1
That one is specially a pain in the ***.
Any idea?
(I tried ctrl+N, It didn’t work)
(I also tried changing between all the IU with the upper-left buttons)
You have ZBrushCore, not the full version of ZBrush. You need to make sure you are watching videos that are for ZBrushCore, otherwise you will have problems.
You don’t need the ‘S’ shaped tool, or Edit mode. ZBrushCore is always in Edit mode.
To import an image for the Draw grid, go the the Texture menu and press Import. Load the file you want and it will then appear in the Draw grid pop-up.
That explains a lot xDDD thank you!
One more question; when I’m using zspheres, Can’t I sketch with them? I saw somewhere that after using a zsphere, you press shift+a and then, after picking a material, you can sketch over the zsphere, but I cant. Is it because of being zbrush core?
Thanks!
