Is there a direct way to change the order of the brush icons within an imm brush without loading it as tool, changing the order in there and then re-saving it as new brush ?
The best way I know of is to use the IMM Extractor plugin, re-order the subtool list and re-save the brush.
With IMM brush active and specific IMM selected Brush:Copy One Mesh.
Then select IMM elsewhere in the brush and Brush:Paste Insert. The Copied IMM will be inserted in the postion before (to the left) of the laste selected IMM.
Then select the original IMM and Brush:Delete.
Save you IMM.
You can also Copy All Meshes and Paste Insert all of them, followed by deleting duplcates as required.
Hi ZBER2, great to know if you want to redo the whole imm brush.
Thanks a lot !
Hi TOBOR8MAN,
Perfect, this is exactly what I was looking for.
Thanks so much !
Just wondering why you marked your post as the solution when it was @tobor8man that solved the problem for you. You should have marked his post as the solution.
My mistake, I was not not sure how that works. Thanks for pointing this out !
