While using the Dam_standard brush I noticed I would get dotting instead a smooth line if brushed too quickly …the stepping setting on Free Hand stroke on locked in Edit mode.
To Increase the Alpha stamp rate on Sculpting Brushes for smooth Quick strokes:
Turn on Lazy Mouse, Set LazySmooth 0, Set LazyRadius 1, and set LazyStep to a small non-zero number
When I left LazyStep @ 0.25 it worked wonderfully for the Sphere Brush, but for the Dam_standard brush I had to set LazyStep to 0.000067 for silky smooth Crests an Peaks
I noticed that if LazyStep is 0 it seems to disable Lazy Stepping. If you turn on Brush auto smooth on and Alpha AA with LazyStep set too small but not zero, ZBrush will lags-out and it might distort pen-pressure sensitivity …at least on my P4 system.
Thanks goes to Marsyas & spaceboy412 for passing this info. on to me.
