Is there a way of importing a bitmap file - a .psd for example with its transparency intact.
Auricks tutorial:
http://www.zbrushcentral.com/zbc/showthread.php?t=20352
suggests:
“You can also use this technique if you have an image with an alpha channel. Import the color into the Texture palette and the alpha channel into the Alpha palette. The texture can then be painted using the alpha for control.”
Has anyone tried this? I can’t seem to get it to work for me. (Though I do have a history of missing really obvious things)
While I’m here. A related feature request:
Could a future version of ZB support PNG files with embedded transparency?
