import photosop(abr) brush ??
hi
there is huge collection of photoshop brush
so is there is any way plugin or something kind of trick that can import
photoshop brush (abr) in zbrush alpha.
i have a thousands of brush so they can not export and import in to zbursh
is there some possibilities…
It’s not possible at the moment.
Right now, the only thing you can do is convert each brush manually. In Photoshop make a small square blank white image, say 400 by 400 pixels. Then draw a single stroke of the brush in black, or just use one click of the mouse to apply the tip to the canvas. Some brushes may require you to turn off scattering or other options. Some brushes you may want to keep scattering on. It just depends on what the brush was designed to do. Anyway, just save the small square image and import to ZBrush. You’ll have to invert the colors in PS or ZBrush before using. I’ve done this with several of my PS brushes and it works fine.
When you export from Photoshop, you should use the 16-bit Grayscale PSD format. That will give the best results when importing into the Alpha palette in ZBrush.
thank u very much all of u.
it is very helpfull.
thanks again.
