I sculpt miniatures and I have a bunch of insert meshes of things that I use often (bolts, ropes, rivets, buckles, etc) and they have all been carefully set to a specific brush size so they draw out at a specific consistent scale that I know looks good when printed out at 32mm scale.
I use A LOT of these insert meshes on every project. I recently discovered that I should not be saving them into my BrushPresets folder, and should instead save them into the Zbrushes folder and load them in through lightbox as I need them in order to avoid technical problems.
Well I often need a lot of different insert meshes, and I often need them often. For example, I have like dozens of different “screw” insert meshes of varying sizes and head types etc depending on the situation. Having to load them in individually through lightbox as I need them is a nightmare.
So I thought creating an IMM brush with all of the “screw” variations contained in it would be the solution. I noticed that each individual insert mesh within the IMM brush can have individual depth settings. But as far as I can tell, all of the insert meshes contained within the IMM brush cannot have individual brush size settings. This is a huge problem for my workflow because, as I stated earlier, the insert meshes need to draw out to a very specific size, and due to varying shapes and whatnot, some of the screws need to be set to a different brush size in order to draw out at the correct size.
So is there any solution or workaround to this problem? Can insert meshes within an IMM brush be set to different brush sizes? Or is there any other workaround to allow me to have my bits box of carefully tuned insert meshes quickly at my fingertips?
Thank you to anyone who can help!
