The primary way is to start with a low poly mesh and project the details of your high poly model. Then subdivide and project again. Keep going until you have subdivided to a level where you’ve captured your detail. There are several projection methods but the newest and easiest is History Projection. Look it up on AskZbrush or Michael Pavlovich’s YT channel Project History
You can get you’re starting low poly mesh in a number of ways. For example ZRemesh and keep reducing until you have a nice quad, low poly model that captures the basic form. Or you could start with a simple quad model made from a primitive and ZModeller.
Note that maximum polycount for a single subtool is 100M polys and each successive subdivision increases polycount by four. So if you really want/need to max the polycount then think about the size of your starting mesh. 1500 polys will get you to 98M polys at subdiv level 9. But you should consider whether you actually need this many.
I would just like add a couple details to tobor8man’s excellent post.
I will just link the classic detail projection methods here because it’s useful to understand the core process that all of these are based on.
Decimation Master is excellent for crunching the raw polygon count of a model down while still preserving detail to make it manageable in external applications, or even to reduce an ultra dense mesh so that ZRemesher can work well with it. It is ideal when exporting a model for print, but produces topology that will be unsuitable for many other processes associated with digital render. In those cases, you would want to use ZRemesher or manually re-topologize your mesh.
Sure, there are a few tools in ZBrush that you can use to remesh a high polygon count model without losing detail.
ZRemesher: This tool is designed to create a low-poly mesh that retains the high-frequency details of the original model. It works by automatically adding and removing polygons, and it can be used to reduce the polycount by up to 90%.
Decimation Master: This plugin is another option for reducing the polycount of a model. It works by decimating the mesh, which means that it removes polygons based on their importance. This can result in a more efficient mesh that still retains the overall shape of the original model.
Manual retopology: This is the most time-consuming option, but it gives you the most control over the final result. You can use ZModeler or other tools to manually create a new mesh that matches the original model’s shape.
Which tool you use will depend on your specific needs. If you need to reduce the polycount significantly, then ZRemesher or Decimation Master are good options. If you need to retain as much detail as possible, then manual retopology is the best choice.
Here are the steps on how to remesh your high polygon count model using ZRemesher:
Import your model into ZBrush.
Go to Tool > ZRemesher .
In the ZRemesher dialog box, set the Target Polycount to the desired number of polygons.
Click Remesh .
The new low-poly mesh will be created.
You can then use this new mesh for sculpting, rendering, or exporting. Here you can find ready 3d furniture models of different products.
I hope this helps! Let me know if you have any other questions.
