How to smooth whole mesh all at once?
Hello, how can i smooth the whole mesh (just if i would paint the whole mesh with smooth (stronger) brush (which would be tedious) all at once?
I thought about using the smooth option under deformations, but it doesnt seem to work (it doesnt smooth the mesh at all, even if i apply if several times)
There has to be some way in zbrush to do this…?
In Tool > Deformation, try out some of the Polish and Relax options.
The open and closed circle to the right of each slider, will give different results.
A closed circle will smooth without volume change, an open circle will be more aggressive smoothing.
Hope that helps your situation ~ cheers
Dynamic subdivision(hit D) is the quickest way I know of. Geometry>>Divide. You may wish to select SmoothUV as well.
