Hello,
I am trying to fix my model. After trying to smart resym my model i have discovered that my model is not perfectly symetrical (despite the fact that i have been able to work on it in symmetry mode). It basically says that no symmetry stored or somthing to that effect.
Anyways, i figured the only way to fix the model was cut the model in half in zbrush. Then import it into Maya to mirror it back together. however i am having several issues with this method.
The center line is quite messed up. I am able to get this lined up and mirror it in Maya at Sdiv 1. However, I lose all my higher subdivision levels - if i export and then import it at subd 1. However if i try to do this at sdiv 4 i get into alot of trouble. Since my center line is so screwed up, the tiny polys make it imposible to line up without messing up the geometry (overlapping etc).
Is there a workaround? I am looking for any possible solution here.
Any help is much appreciated.
Thanks,
mike
