Hi
while using my tablet when i initially try to use the pen I get a white circle gradually appear which then opens a meanu I realy dont want. how do I turn this feature off? its really frustrating and i cant find an off setting in config. Thx
Hi
Can you post a screenshot of the menu? A “white circle” menu sounds like something from your tablet, not zbrush. If it’s a zbrush menu, we need to identify which one you’re referring to.
The “white circle gradually appearing” makes it sound like the Windows Pen and Touch settings which treats a press-and-hold as a right-click equivalent. If that’s the case you should be able to find options in your Control Panel to turn this off.
The newer versions of Windows 10 have switched things around a bit, but if you’re using a Wacom tablet then you may want to check the Wacom Tablet Properties for the option to uncheck “Use Windows Ink”.
ok thx… its a wacom tablet, and it is treating it like a click. ill look in the wacom control panel … thx
Hello everyone, I was having the same problem, but I realized that the “white circle” is actually a Wacom Tablet option. To disable it go to Control Panel / Pen and Touch / double click on “press and hold” and disable it.
I hope this can help not only you, but everyone who ends up on this page with the same problem, as I did.
I made an account just to like this post.
Thank you for posting this 2 years ago
