How do I render and export images?
I’m sure it’s very simple, but I don’t know how to render an image at a high resolution, and export it…
Also, I can’t seem to get good antialiasing on my model.
any advice is appreciated
thanks
this is a problem we all have on the begining!
use a canvas very big - and at the end (after rendering) use Zoom - AAHalf
or the blur brush after baking :smiley:
For rendering go in the Render Palette(Menue)
there you have many attributes to tweak…
dont forget lights…
after rendering in best render you can export your image in Dokument->Export Menue
AAhalf is “CTRL” + 0 (null)
Pilou
Adding to what has been said, ZBrush will export 72dpi. You can then resample this in another application, should you need to.
To export the image after rendering and activating AA Half, simply press Document>Export.
Thanks! I’ve got it now…
