I am trying out the demo for ZBrush, and have tried to accomplish this with no real success. I need to be able to draw an object such as a cup, and to be able to make it appear to be composed of semi-transparent plastic. The real trick here, is that I need the edges behind the front of the object to be visible THROUGH the object, as any TRUE transparency would provide. With ZBrush, it seems that the only thing that is visible through the transparent object, are OTHER objects behind the transparent one.
Any help would be greatly appreciated.
approach, Matthew! i gave the technique - as i understood it - a try and it basically did what is expected, but i have had trouble to cut it in half properly + i need to do lots of research re: refraction to make it look like it should. i attach a
), mayhaps you find the time to have a look and to tell me what could be done to improve the effect - and how to get rid of the seams when adding the front part
