You could start by showing the actual UVs so we can asses the problem with the UVs.
here is the uv map:)
Well, your Mesh looks like it was auto generated inside of Zbrush, as well as your UVs. If you want to get a clean unwrap on that object I would recommend building a proper mesh and unwrapping the object.
my 2 cents anyway.
