Here is my first ZTool I created with 1.55b - Rock Water Fountain.
Here is my first ZTool I created with 1.55b - Rock Water Fountain. Texture included in the zip download
Water Rock Tool.zip
At Pilou’s request i downsized the texture and embeded it into the tool a few posts down
The tool is a rock for water to flow down from.
Have fun using the ztool
Your comments and suggestions for improvement would be helpful
TIA
SpaceMan
Many thanks for your thoughtfullness.
Thanks bicc39
Have some input on how to improve it please post and/or post some images you used it with would be cool.
Hi Space
A demo user can’t load an Image!
But he can load a tool with a texture :slight_smile:
So put your image on a plan 3D for example
Save your tool
And into your script just load the tool during the process !
You must have the texture with it :slight_smile:
You are not oblige to use this plan 3D but the texture is inside!
So you can use the texture for all that you want :slight_smile:
I am waiting your next try :slight_smile:
Hope this help!
Pilou
Pilou thanks for the remarks.
I saved the tool with imbeded texture and it is about 3megs when zipped and the upload to fourm is 500k according to the upload info before uploading- has that changed?
TIA
So try just just with a simple “Zsphere” as a 3D object :slight_smile:
Of course maybe if your texture is 4096*4096
maybe is effectivly some big :slight_smile:
Pilou
To SpaceMan: thanks for your great ztool rock and also for the material. I made this post dedicated to you and your actitude to share¡¡
Thanks
Andreseloy
WaterRock Tool with embeded texture.zip
andreseloy
Cool image from the simple tool thanks for posting it. The water swirls in the tool working or is that your added work - the added color over of the blue water is cool.
NOTE: working with the tool I think caves could be created. Editing inside the object not so easy for me as I am new at doing it. I can not get the hook brush to active in edit mode which I think making a cave scene easier - does the hook brush actives in edit mode?
Thanks SpaceMan i like you like it¡¡¡
They were made with sphere3D>stroke>colorized spray>color variance 0 and GelShader1 material in a second layer wint 82% transparency.
(In render panel flatten layer off).
Thanks again
Andreseloy
(Texture from SpaceMan)
Hi Space
All works fine!
Here some doodle with your Texture ! :slight_smile:
(frame is not Zbrush but you can make the same with the Cameyo fabric texture!)
I was speedy '30 secondes :rolleyes:
Pilou
Ps In edit mode you can’t take any tools !!!
else that exit you of the Edit mode :frowning:
Pilou :slight_smile: that it works
Cool image abstract and I can see the city scape too.
Thanks for posting your image
:cool:
I don’t know another programm for make funny textures with shadows (or not)in so few times :slight_smile:
Pilou
Ps the next time I will make a “tilable” texture !
It’s also very easy :cool:
