Help with missing materials & toon shader!
Hello :smiley:
Ive been zbrushing in an ‘ink’ material that someone posted. Basically im looking for a cell shading type of effect and I read in one of the links that in ZB1 there’s a toon shader material?? I havent got it in ZB2 and i need as many materials with a black and white or shaded effect as possible!
Can anyone please help??
Many thanks,
Matt.
There are several materials included in the ZMaterials folder.
As for a toon shader, all you need to do is modify the Diffuse Curve so that it forms a stair step. Or you could do a search here at ZBC; I think a few people have shared theirs.
here they are!
Thanks for the help! :+1: :smiley:
Zip file was just what i was after! :smiley: :smiley:
hi Mattie
Polaris has posted up quite a few versions of toon shaders, you might want to check his out…I think they are all color ones but would be easy enough to adjust to a black and white version and it may have different effect than the one Bas gave ya…so you have one or a couple more options there.
Also I think Jason Belec posted up one or two he was working on that could also be adjusted. A few more options!:smiley:
there might be more but these are the ones off the top of my head.
Hi Aminuts,
Thanks for the info, ive had a search around and got quite a few materials which seem to work pretty well. Still trying to find a really tight black and white shader that ends up looking like a pencil drawing… just got into silk screen printing t-shirts, so the less colours the better! :smiley:
Thanks again,
M
Have you seen this?
