HELP PLEASE! SIMPLE COPY AND PASTE UV NOT WORKING
OK. SO am I doing the most EASY AND BASIC task, and it WILL NOT WORK!!!
  1. I make a sphere and write test on it. HIGH RES
  2. I duplicate the sphere, Zremesh it. LOW RES
Zplugin, uvmaster:
-I make clone on low res, I unwrap, flatten to check UV’s, copy and paste the UV’s to low res model. WORKS.
-I copy and paste to HIGH RES model. DOES NOT WORK!!! WHY!!!
(LOW IS THE HIGH RES MODEL ZREMESHED)
Thank you.!
UVs are dependent on topology. You can only paste UV’s onto a mesh that is topologically identical. If you have ZRemeshed it, the two meshes are not identical.
OHHH, of course yes. I take the low res into Substance and project the high res normals from zbrush, so I don’t need the high res UV’d anyway! Thanks!!! Makes sense.
I got all my textures, normals out of zbrush to substance. THANK YOU!!!
