Hair Stroke
Is there hair stroke tool I can import in ZBrush?
I tried Fiber Brush but it is not I what. I want a hair stoke that paints directly to texture map applied on 3d object.
Thank you in advance
Hi Washington
Go to the Quicklinks and type “hair” in the window text research of your Navigator!
You will find 8 threads about making hairs !
Hope this help!
Pilou
Thank you for the links. I still did not find a post I want. Do Zbrush have alpha channel (Transparent)?
Can ZBrush make texture map like this?
Hi Washington
Menu Draw/sub Menu /Channels can maybe help you !
You have also a tut inside the prog about transparency!
And you can play with the Rgb regulate 0 to 100 intensity!
And you can use the Marcel method to apply a real hair to a volume3D!
Troll thread
Pilou
There is a tutorial from Steve-Z Rae where describe exactly this point and very similar hair type you chosse in this photo
Andreseloy
ps: press search at upper right page
the image below is an exercise with your photo, you can with MRGBGrabber make texture and alpha of what ever¡
This qucik model used the hair of your photo
Hairs by Ztevie Rae
I think that is the thread about Andre talk :slight_smile:
Pilou
Thanks for the TIPS I definately will use it!!! One more thing I need to know is how to make hair brush stroke to paint on the texture map?
Like this one but more thinner lines
Other question after making hair texture map how do you convert the black backcolor using hair texture map into tranparent map? I probably need step by step tutorial because ZBrush have so many functions to click on.
Just down the words “your photo” is the transparent bottom¡
Hope this help.
Andreseloy
Hi Washington
You have a button “tranparent” in the Sub Menu Texture :slight_smile:
So all pure black color will become transparent !
Pilou
The key with ZBrush texture transparency is that ONLY a color value of 0,0,0 will render as transparent. Even 0,0,1 will render as black instead.
To create your own brush strokes, create an alpha. You can do this by painting a few dots on a clean canvas and then using the MRGBZGrabber to turn them into an alpha. Alphas are used to modify any brush.
Thank you for the tips and love you all!! :smiley:
Aurick your tip have over a million of brush strokes!!
How do I save a brush stroke with mineral and color settings?
Other question how do you avoid brush from color build up when it is brushed again?
