Hey
Can somebody help me install GOZ for 3ds max 2021.2, im getting “unable to cope” error.
Thanks!
Hey
Thanks!
What is it exactly that you’re trying to do? See, you may not even need to set anything up manually, things could already be working out of the box (or they should).
Even so, I looked around and found an article which explains how to manually set up GoZ for several applications, check out this link.
Hope this can help you out, if not then please explain what it is exactly that you’re trying to do and where it failed for you.
Look in your “Program Files/Pixologic/Zbrush 2021/Troubleshoot Help” folder and you will see two files. One is “GoZ_for_ZBrush_Installer_WIN.exe” and the other is “GoZ_for_ZBrush_Installer_WIN_3DSMax_Legacy.exe” Try the first one first and if that doesn’t fix it, try the 3DS Max Legacy one.
