GoZ and Subdivision levels
I’ve been using GoZ for a while now with LightWave but was just using it today and each time I send a model from Zbrush to LightWave and then back again, topology changes I make in LightWave modeler don’t prompt Zbrush to tell me that my topology has changed like it did previously and also, my model comes back without its subdivision levels. Also, my UV map information is no longer there so I’m not sure what’s happening other then its simply sending back level 1 subdivision. It used to tell me that I’ve changed topology and do I want to reproject.
Also, my GoZ for Modo 901 doesn’t appear to work at all but I think that’s a 901 bug, I’ve heard others mentioning it.
Check that the name isn’t getting changed, so that you are getting a new tool in the Tool palette when sending back to ZBrush. GoZ relies on the name staying the same.
I’m afraid I don’t know about Modo 901.
From everything I’ve gathered, Pixologic changed something with GoZ and has broken it with LightWave and Modo. Hoping there’s a fix soon.
