I recently downloaded the new Zbrush 2023.0.1 and it didn’t carry over the custom UI i got used to using on the last version of Zbrush. How do I export it from Zbrush 2022 version to the new Zbrush 2023 version? It took me quite a while to create and it I would it would be super appreciated so I dont have to rebuild it from scratch.
thank you
Hello @Zoda ,
You can save out a custom UI in any version of ZBrush by using Preferences> Config> Save UI and then load it into any version by using the Load UI button.
Once loaded into the program you can store the UI to load at startup by using Preferences> Config> Store Config.
Please be advised that while many times you won’t experience problems doing this, any time you create a UI in an obsolete version of the program and port it forward into a newer one, the possibility exists that something will have changed in between versions and the old UI will cause some sort of trouble. If you experience issues after loading the UI into the program it may be necessary to re-create it in the new version of the program.
