Error Code: -1 after trying to import .FBX from Maya 2018
Hello, I am a beginning Zbrush user – and new to computers and 3d art in general – so please forgive my ignorance, but I am having some trouble getting compatibility between Maya 2018 and a trial version of Zbrush 4r7.
I am using the Zbrush FBX export import plugin, attempting to import an .FBX file that I created in Maya 2018 and Mudbox 2018, but I get an error code : -1. After that, a pop up says that the tool was loaded, but it is nowhere to be found.
I understand there is some compatibibility issues between Maya since switching to Arnold and Zbrush, but so far all I have read is that those issues only related to the GoZ application – I understood that importing/exporting fbx or obj files should still work fine.
Any help is appreciated – I really have scoured the web and can’t find any information that helps me.
If no good option exist, I suppose I will just install Maya 2015 and work from that, although I do like some of the new features of Maya 2018 so a better solution than reverting would be fantastic.
Thanks in advance for advice.
For some reason the FBX plugin can’t read the FBX scene format. This may be because you are exporting using a higher FBX version number than the plugin can cope with. Try exporting the FBX again from Maya and make sure to select a FBX version of 2014 or earlier. (You will be able to do this from the FBX dialog options.)
Thanks, that did it. Now I can continue working in the version I’m more comfortable with.
