If you wish to erase pixols from the canvas, use the EraserBrush found in the Tool palette.
If you wish to erase sculpts that have been made to the model, you must store a morph target (Tool>Morph Target>StoreMT) before you begin that sculpting. This then makes the Brush>Morph brush available, with which you can sculpt parts of the model back to the stored morph state.
If you wish to erase sculpts that you’ve done to the model and have NOT stored a morph target before sculpting, your only option is Brush>Smooth. If your original surface was smooth, this brush will allow you to return parts of the model to that state. If your original surface already had some detail, though, there’s not much you’ll be able to do with Smooth.
