Hi
Some of you are already familiar with this info…
There is a 3D text utility that can create text from any true type fonts and export in dxf format.
I have downloaded the utility and exported a test “ZBrush” text.
In ZBrush, I selected the PolyMesh3D (StarTool) and imported the newly created DXF file and used it to create the following test image…
The utility is very simple to use and it allows you to create text that can be used within ZBrush… Until ZBrush gets a Text Tool, this utility can be very useful.
Here is the link … http://www.armanisoft.ch/webdesign/default.htm
Unfortunately, this is a PC version only There are many Mac users in here and it would be good to find similar application for the Mac.
If you know of any, please post the info in here.
-Pixolator
