DXF 2D to ZScript
Hi ZBrushers,
i did a promise…
Here is the program (written in Delphi) to convert DXF files into ZScript.
You can edit the Zscript to alter some parameters (DrawSize, Material, RGB Intensity, ecc. )
Download: DXF_Z.zip
Try with your DXF.
Example:
With this program i have converted the images within SanTommaso and CappellaNiccolina threads.
Post your result and feel free to ask any question. Please report any error.
cameyo
p.s. EZ, Stonecutter, Kathy: i have sent the ZBR you had request.
Hei Max!!! Very very goog script!! Usefullll!!! :+1: :+1: :+1: :+1: :+1: Tnx for sharing!!!
<Font Color=#FFa000 Size=2> Zciao Max!! </Font> If i have Autocad 2002, in wich type of dxf do i save the file?? :smiley:
That looks like a nifty utility. I’ll have to try it out sometime. :+1:
Anyone know of any freeware .DXF drawing programs?
Very, very cool effect!
Free drawing DXF
Some programms are in this links !
http://bryce2-2u.freeservers.com/bryce-links.htm
http://www.freewarehome.com/Graphics/3D_Graphics_t.html <A HREF="http://home.pacbell.net/tylereng/bkmrk999.htm" TARGET=_blank>http://home.pacbell.net/tylereng/bkmrk999.htm</A>
and this big one http://3dvf.com/logiciels/freesoft.php3
Pilou
thnx C, just downloaded it and will play with it later…you are very generous :+1: :+1: :+1:
ok…now I just ran it…and this is where I become stupid…(once again) What type of dxf file should I use…and what should i be expecting this to do? I had only 2 dxf files on the computer and it said 0 polygon counts etc…so I cut and pasted the text on the Converter program you made and put it in notepad and saved it as a txt and ran it in z…this is the information that I cut and pasted…
Date: 6/17/02 - Time: 9:40:20 AM
FILE N.1: C:\Program Files\MetaCreations\Poser 3\Runtime\libraries\props\New Library\5inl.dxf
ZSCRIPT succesfully created.
Blocks: 0
Lines: 0
Polys: 0
Text: 0
Number of Objects: 0
DXF Rows: 22548
Tempo: 12:00:00 AM
Total Time: 12:00:00 AM
Date: 6/17/02 - Time: 9:42:19 AM
FILE N.1: C:\Program Files\MetaCreations\Poser 3\Runtime\libraries\props\New Library\5inr.dxf
Blocks: 0
Lines: 0
Polys: 0
Text: 0
DXF Rows: 22548
Tempo: 12:00:00 AM
so what do i do with the info…and btw.the dxf files i used I have no idea what they were…they were the only two I had and they were in my poser directory…thnx for your patience…
:o
This is really neat stuff! The results are gorgeous. Thank you for your generosity.
Ron, there are two kinds of .dxf files. The 2d kind and the 3d kind. I think this program is made to only handle the 2d kind like the kind that 2d cad drawing programs generate.
thnx WO,…then that clears that up :+1: :+1: :+1:
Brava!! Cameyo!!
Great stuff here. Thanks for your hardwork and knowledge.
:smiley: :+1: :+1:
Thanks for the sharing, cameyo. :+1:
It looks very cool tool.
I can make precise illustration on ZBrush.
For background, mechanical object or so…
Very useful!!! :slight_smile:
I’ll try this soon and send report.
Thanks. :slight_smile:
kaz-g
Thank you all.
The program works only with DXF created by Autocad. Export the DXF in version 14 is better.
To begin try this DXF:
Demo.zip
I hope to have time to correct and enhance this program.
Do you want the full source? Send me an email. It is written with Delphi 5 Professional.
cameyo
please send me the source ill take it.
thank it worked great :+1:
