Do you have another way ... UV master
i watched the clip and did it on the basic round ball
but when using UV Master. it gives very long UV time and the result is not very nice
if i don’t UV from the beginning then when using Sunface, ALpha will not follow the curl of the hair brush
thank you
I don’t know if this will help you, but I’ve noticed UV Master generally only works on simple geometry.
I export subtools and create UVs in another software.
