For the life of me, I cannot get Polypainting to work properly. No matter what I do, it does not work.
I tried this tutorial - file:///C:/Program%20Files%20(x86)/Pixologic/ZBrush3/ZHelp/Painting_a_Head.htm
the results were that after clicking colorize, my model turned blue, and when I try to change the color or material to paint, the eyes subtool would change automatically, and nothing would affect the rest of the model.
No other tutorial seems to follow the steps I need to take, it’s like I’ve got some special trick version.
I’ve got separate installs for 3.1 and 3.5. I have a preference for 3.1 because I plan on outputting for use in UDK, so I’ll have use for Decimation Master.
I really need some help, I’m about ready to give up if I can’t get this to do something that should be ridiculously simple.
To sum up my issues: I can’t select materials or colors without it automatically changing either the entire model to it, or the eyes subtool.
The options available don’t seem to reflect the options in past tutorials, and even when I follow step-by-step the various instructions it still will not simply let me paint on the model, or paints in a flat, highly saturated bright blue.
Using projection master sometimes works, but then I can’t get back to the rotatable 3d editing view to continue work.
Thanks in advance for any advice! I’m loosing my mind.
The blade is badass. You can make countless shapes. Really cool feature.
