I froze subd levels but made changes that don’t require them anymore. Is there a way to delete them so that I may freeze new levels?
store a morph target.
unfreeze subDs
switch back to your morph target.
work as normal.
You can also use the MakePolymesh3d button to essentially clone/duplicate the model at its current state.
Thanks. I ended up making the polymesh3d object because the morph target didn’t work for me. After I unfroze subd’s I wasn’t able to switch the morph target.
Thanks a lot
Had to do the same. makepolymesh3D is the easiest way to go. Thanks.
