Ctrl-shift (solved)
When I use the key combination CTRL-Shift I get this pop-up instead of being able to Select and switch between groups. How to change this please ?
that doesn’t sound right, the popup should only show on spacebar or right click.
check your hotkey file in the zstartup/hotkey folder
At the risk of saying something really stupid…that shouldn’t happen. Are you certain you’re Shift-Ctrl left clicking on the model, and not right clicking? Right clicking will bring up that quick menu.
Do you have any hardware/software/custom configuration that may be switching the left and right click behavior?
I’m using ZBrush Windows under Parallels on a Macintosh.
I know thre is something about modif on the keyboard
Found the solution in the Parallels prefs
