New user here. I recently got started with Zbrush and am using a custom UI with favorite brushes docked in the bottom shelf. My issue is with the brush menu Quick Pick window, which becomes cluttered as a result. To better explain :
The standalone brush panel (the “B” popup) isn’t a problem, however when I dock the full Brush menu in the left tab the expanded Quick Pick is hogging that space. I tried using the “R” button to reset it to a reasonable brush count, however for some reason the shelved brushes are apparently locked in there. Removing favorite brushes from the shelf does also free up their Quick Pick slots, but the point was to have them close at hand in the first place.
Am I doing something wrong ? Is there maybe a way to collapse that quick pick panel ? Or maybe a way to dock individual brushes without locking them in the Quick Pick panel ?
I searched a bit and found a topic related to that same problem but didn’t want to resurrect it seeing how it’s 2 years old and the person didn’t find a solution back then.
