Can I save project without being asked if I want to replace it?
I like to save my projects as I work. In ZBC, whenever I want to save the current project I’m in, it always asks me if I want to replace it even though I’m just doing a Ctrl+S.
Is there anyway to periodically save a project as I work without having to “replace” it?
Thanks in advance.
I’m afraid there’s no way round that. The alternative is to use QuickSave which you can use hotkey 9 on, or assign your own. If you want to change the AutoSave settings then they are in the Preferences>QuickSave menu. Setting the Maximum Duration and the Rest Duration sliders to their maximum will effectively disable AutoSave. Remember to store the configuration after making any changes (Shift+Ctrl+i).
Thanks again.
