Hey guys, I appreciate all the help in these forums! I have a file that is in Blender but I want it in Zbrush. So far I have not been able to get it over. Any ideas?
Hi @buck27
There is GoB. It’s a GoZ between Blender and ZBrush. Link below. Other than that, you have to use OBJ or FBX files.
First, thank you for the help.
so I downloaded the files, unzipped, went in Blender and added them to the add-on install but I do not see them anywhere
You don’t have to unzip the files. In Blender > Preferences > Add-ons, click install and navigate to the zip flie and select it.
You also might have GoB installed already but an older version. In Blender Add-ons, scroll down until you see “Import-Export:GoB” then enable it.
In “C:\Users/Public/Pixologic/GoZApps”, there should be a “Blender” folder. If there isn’t, in the GoB zip file you downloaded, there is a Blender folder. Unzip the file and place that Blender folder in “C:\Users/Public/Pixologic/GoZApps”. Then, in ZBrush, you have to enable Blender as current GoZ application. To do that, Click on “Tool > R” and select “Blender” (see image)
When done, you should have two new buttons in Blender. (see image)
Â
Working on it right now! Thank you so very much for helping me out. I was able to get the app installed in blender now and have the 2 buttons up top. I am now trying to get Zbrush to find Blender but I think because I downloaded through Steam it doesn’t see it.
Ok, I got it to find Blender but its now telling me to set my zbrush path?
Can you post a screenshot of the message? Also some help below to get you started.
Locate your ZBrush .exe file
OMG! I feel so dumb right about now!
Thank you
You’re welcome! No problem.
how to fix it?
