Which is the best rendering software, one which can render project to look like from the real world (for example: model of human face). Does every software has that option, or just some of them? I wander for both - photography and animation rendering
pretty much everything can do it. but do some research before deciding on which engine you choose to use
Thanks man. I hope someone can suggest some rendering software or plugins
Maya seems to be a popular choice and does good renders (i’m untrained, just seen stuff here that’s good)
Yes, I also used Maya rendering once, but for buildings, not for human faces, sa don’t know. Also I heard that for Avatar is used Renderman for Maya, so I think that is the best… :rolleyes:
Renderman, Mental Ray, Vray, and Maxwell are the best, but none of those are a one-click-to-make-it-look-real solution.
The rendering process involves the talent of the artist, in other words, you can get photorealistic results with zBrush renderer and photoshop.
I guess so. Thanks for answer. Did you know some useful tutorial, which explain the process of creating photorealistic render?
P.S. I assume that Photoshop is used for texturing…?
I could upload some lighting setup pics as soon as I go to work, and explain a little… you can start by researching a little on “Final gathering” if you want to render with mental ray.
Photoshop is used for compositing: In the rendering app you render some “Passes”, an ambient occlusion, A plain color, a specular color, a reflection… and get them together in photoshop/After effects/Fusion/Nuke…
Ok, I understand now Thanks in advance
Also I know now that I’m in very beginning of CGI-world, so there are lot to learn :))) Thanks for help!
sorry for the delay… here is a rendering tutorial
http://www.zbrushcentral.com/showthread.php?t=83524
cheers!
Thanks for answer, it will be usable :))
