background always black when rendering bpr
Hi
Whatever background i define, the shaded bpd render is always black (see: bpr_render.jpg).
How to get what i see or set up as background (see: screengrab01.jpg)?
regards
theo
Texture>grab doc then save as should work.
http://www.pixologic.com/docs/index.php/Document_Palette
hi
thanks for responding. That works well. But shouldn’t the shaded bpd channel produce the image i see?
In 4r4 it was so. Now something is different. It’s not the same behavior any more in 4r5.
Works as expected here. Set your document color first, though that may not be necessary or better.
p://www.pixologic.com/docs/index.php/Render_Palette
To export a render exactly as you see it use Document>Export.
The Render>BPR RenderPass menu is designed for those who wish to composite render passes in other software such as Photoshop. That’s why the ‘Shaded’ pass has a black background. The edge of the model in that pass doesn’t have anti-aliasing, so that the background colour doesn’t affect the result. You would use the ‘Mask’ pass to isolate the model and composite the background of your choice.
hi
thanks a lot for your help. So, this bpd-shader-pass is the way it is supposed to be.
I wish you a happy new year.
regards
theo
Yes, that’s right. If you want the background color/gradient included in your render then the image saved using Document>Export gives you the best quality.
Happy New Year to you!
