Applying a Keyshot material fromt the library without removing polypaint data?
Hi I was just wondering, is there a way to apply a Keyshot material fromt the library without removing polypaint data when using the keyshot bridge?
I don’t have Keyshot but I believe you hold the alt key while dragging over the model.
Hold alt while dragging a material in Keyshot to change the surface properties but leave the texture. Note that not all Keyshot materials support color textures, so polypaint will be lost with some material types no matter what you do. This only changes surface properties. If you want it to react to the material color, you’ll have to enable the “blend with color” option in the material properties menu.
