Angel figurines
Title: The beginning of fate
I created the motif of an angel holding a flower in his hand.The sculpture can be enjoyed from various angles.
We modeled from multiple angles to create a design that would never get boring no matter how many times it was viewed.The way the work looks changes depending on the viewer’s state of mind.The world view and story of the work will also change from time to time.
It is designed to be used as a game accessory or room decoration.
Sculpture 3d print model May be used for 3d printing, Rendering, etc. File Formats: .stl, .obj,
The model measures: Height: 20 cm
If you need to change the size, you can always load the model in any 3D package and scale it or do it right away in your software for a 3D printer.
This is a 3D printable model, the files are mainly cut and tested for resin printers, but will require skill to produce.
