All Alphas download (solved)
I recently downloaded “all alphas” to the startup alphas file.First thing is it wont open on startup.I have to go in to import to retreive all the alphas.Once I do that they are displayed in the alpha pallet, most of them anyway.But I lose the edit buttons on the bottom and it seems the pallet cant handle all of them.Am I overlooking something? Didnt 3.5 have some kind of downloadable format for extensive files?
You can put them into the ZAlphas folder so you can get to them with Lightbox. Nearly 600 alphas is a bit too many to load at startup and display !
How is that done?
If you’re using windows create a shortcut to your All-Alphas folder and put it in the ZBrush / ZAlphas folder. Open Lightbox, select Alphas, select the folder shortcut and bingo.
Shortcuts don’t seem to work yet on OSX
Online Doc for Lightbox http://www.pixologic.com/docs/index.php/File_browsing_with_Light_Box
Thank you Sir!
