Adding eyes?
I need to know how to add eyes to head without eyes, everything is sculpted, just need to know how =\
Bizzaro cloud,
First you need to right click and go to the marker icon then select it. This marks the position of your original mesh.
If you go to the tool menu it will give you a choice of different
primitive shapes. Pick a sphere shape and use this for the eyes
of your character. Zbrush will ask if you want to switch tools because you can’t work on your model and the spheres at the same time. Use the Gyro to position the spheres into your character.
Once done right click and mark each eye. Use the snap-shot function to match both sphere sizes. It just copies the original sphere. Go back to tool menu and select the multi-marker icon. It’s shaped like an M. Select it and draw your mesh on the screen. Once done you need to go to tool-modifiers-makepolymesh.
Zbrush will rebuild your new character.Go back to the tool menu and you should now see a “composite mesh”. Select it and sculpt away, everything should be welded together.Hope that helps/Odhinn
