3D Text Plugin ~ 'Edit' Function
Hi.
I need to edit some 3D Text created with the 3D Text plugin. I need to go back in and bevel the edges on the faces of all the letters.
The problem is, I don’t seem to be able to actually ‘edit’ any text that is already created.
Right now, it seems the only way to ‘edit’ is to re-do everything with the new settings.
How can I actually ‘edit’ text in the 3D Text plugin?
When I open a file in ZBrush to edit text generated by the 3D Text plugin, the text is not available to edit, only to ‘replace’.
Have attached image. I opened my file, selected the subtool whose text I wanted to edit and opened the plugin and hit ‘Edit’. All settings are default and there is no text to edit. The only way to incorporate edits is to reset all the values and recreate the text with new settings.
I would like to be able to select my subtool/text, open the plugin, edit the values and/or text, ‘apply’ and be done. Am I missing something?ZBrush_3D_Text_01_Edit_Text.jpg
:frowning: Not happening…I’d love to be able to save a file, reload and keep on working.
http://docs.pixologic.com/user-guide/zbrush-plugins/text-3d-vector-shapes/text-3d-functions/
