3D Print OVERHANG MASTER :)
Hi community,
first of all:
i´m no programmer at all.
for my 3d prints i needed a way to show where
there are problems in my 3d models and where
are overhangs during the sculpting process.
so i „clicked together“ this little script
to create 3 polygroups facing towards the camera
45 degree / 25 degree / 20 degree
i can now clean up areas to reduce the need for
support structure without leaving zbrush.
now my question is:
as said - i´m no coder. but i´m willing to learn :slight_smile:
or is it possible to compile this into a plugin.
-> 3D PRINT OVERHANG MASTER e.g
:smiley:
i searched the web but i didnt find anything about
it. where can i search to learn about all this ?
would it also be possible to take the „inner“ polygroups and
turn them in an angle so that there would be no
further supports needed ? of course to a certain degree.
any help is very much appreciated.
all the best
Cosmic
Sorry for the late reply. You can learn about making plugins here:
http://docs.pixologic.com/user-guide/customizing-zbrush/zscripting/interfaces/zplugin-interface/
And you can find more information about ZScripting here:
For your question about rotating inner polygons, that wouldn’t be possible using ZScripting on its own. You would need to code a dynamic library that adjusted an OBJ which was then re-imported into ZBrush.
