I can’t get curve brushes to snap to polygroup or mesh edges by holding shift anymore, brushes like CurveBridge have been rendered unusable and I can’t wrap curves along edgeloops.
Is this a bug or has behaviour/control changed?
Hello @AristotlesLantern
It works OK for me. Make sure you are up to date with version 2022.0.2 then contact Pixologic Support if you are still having the same problem.
As @zber2 , I’m not immediately experiencing any trouble with any of the scenarios you mentioned.
It may be that you’re experiencing some sort of issue with your input device. If using a tablet, try using a standard mouse instead to see if it’s any easier for you.
It may also be you’re experiencing trouble in relation to a specific usage scenario, or that the mesh you are working with is problematic in some way. Please try this with a variety of meshes that ship with ZBrush to rule out some sort problem specific to the mesh you are working with.
If you feel you’re experiencing a technical issue with your ZBrush installation, please contact Pixologic Support. Technical support for ZBrush is not provided over the community usage forums, and any actual issues reported here may be missed.
Thank you!
Hi, thanks for your replies. @Spyndel Easiest thing to explain is a video: https://youtu.be/UoqY2m7S1GQ demonstrating the difference. It seems like it’s not every mesh that it happens on. Simple ones, especially, seem to be fine…
I can upload the mesh if need be. If it makes a difference it was made with 2022.0.2
Seems to be the same behavior regardless of input device.
Hello @AristotlesLantern ,
If you feel you’re experiencing a technical issue with your ZBrush installation and you’d like us to take a look at something, please contact Pixologic Support. Technical support for ZBrush is not provided over the community Usage Questions forums, and any actual issues reported here may be missed.
Thank you!
