ZBrush 2021.6 Troubleshooting
@MEC4D
Please first see Frequent Crashing - Pixologic
If that doesn’t help, please submit a Diagnostic Report. Instructions are above.
wen i want accurate crisp masks i turn on global settings under brush/tabletpressure
or u can use an shortcut to sharpen the edge, ctrl+alt and clicking few times on object makes the border of mask cleaner
I did not experienced crashing after installing the new updates yesterday and working with it for many hours , other little issues solved itself as well , but the only major issue that persist is still the Move elastic brush , polygons still exploding and I had a lot of troubles yesterday with using it to the point I had to stop using it .Screenshot 2021-04-21 081344
also when using insert brushes I am getting weird artifact second window on the screen
Screenshot 2021-04-21 103528
I will submit the Diagnostic Report as well , thanks !
I am having the same issue. Figured out at least in part the problem was with boolean. It chopped the mesh up in to unconnected pieces. After I remeshed it all in to single geometry, decimation master worked.
