Where Is The 3D Reference Tool?
El-d,
To have the texture only display on the plane, disable UVs for the model.
To adjust the transparency of subtools, make sure Transform:Activate Edit Opacity [Transp button] is on and then adjust the Preferences: Draw: ActiveOpc and InactiveOpc sliders are set as you wish.
HTH,
I was able to apply the texture only to the imageplanes by choosing tex->col (after dividing the imageplanes once or twice to get more pixels). That baked the texture into the imageplane, or something like that. :slight_smile: Then I was able to fire up zspheres normally.
I have a slightly different problem. When I work on my zSphere or primitive model attached to the imageplanes, I seem quickly to lose symmetry, and smart resym doesn’t fix it. How do I prevent that from happening?
Have fun you lot. I’m just gonna wait until Ryan announces a video using the cube method :smiley:
Thanks Marcus, You never fail to find the solution. :smiley:
El-d
