Thanks! I wish I’d researched the ‘WS.Reputation.1’ before I posted the question. I would think a lawsuit is in the works. How dare a software program decide another is ‘suspect’ based on… popularity? I thought the stuff was supposed to detect threats. Plus the warning makes it look like there is some form of something wrong with the software. I assumed there was something wrong with the installer. It installed fine once I turned off Norton.
Same here. XML error.
I tried IE, Chrome, and Firefox and they all didn’t work. IE was the only one that was saying Javascript wasn’t working. Chrome and Firefox just pop up and show the busted XML page.
I too am experience custom ui issues :S
After adding a custom menu when I click preferences I get the render menu instead (Seems like my new menu is somehow offsetting something)
Also,
when adding backfacemask to the top bar, I loose Active Points and Total Points. Not right away but after a while / restart.
As it is now, I cant use custom menu :S
Is there any solution to this?
Alex
Maybe check to see if you have th elatest java update? Sory, but other than that, I got nuttin.
The server is working, I am now able to download as I write…
cheers
Jay
Yep - all working now for me as well.
Maybe Justin can grab it now then…
Starting to get annoyed now having to download the 4r4 installer win. exe 4 times, norton sees it as a threat and the 4r4 installer win. exe deletes after each time I download . Is there a way to fix this, I even tried turning off my norton but the 4r4 installer win. exe doesn’t seem to show up.
Server’s definitely fixed. Download worked fine this time, and install went smoothly, as usual. Thanks!
Zbrush r4 custom ui problems - please help!Since r2 and upon seeing the EAT 3D hard surface video…I have been used to the Custom Menu Workflow…If you use this workflow, be prepared to cry a little…
Since then I’ve had an issue which once was fixed with UI_Starter plugin…in r4 it appears that it does not work…
When you make a custom menu or “pallet”- it shoots back in alphabetical order at the top, customize and put all the tools you use and store configs…restart Zbrush and BAM…every time you try to open your custom menu or the lets say “preferences” it opens the “render” pallet…Oddly enough though in r4, everything BEFORE your custom menu works fine when you try to open the pallet, but everything AFTER the custom menu is 1 pallet off…
Not only that but I tried putting some TRANSFORM options “Symmetry, xyz and radial” into my CUSTOM menu, and once I stored and restarted and my strokes section in my CUSTOM menu became " Active Symmetry " followed by “make polymesh 3D, goZ, All, Clone Allsubtools” No idea what that’s about…
1St I imported my r3 settings and tried - didn’t work…then I reinstalled Zbrush and deleted all folders in my program files and in the new Public Documents Folder…made it in r4 from scratch same issue…so It has nothing to do with the old settings being incompatible with r4…If anyone can help I’d appreciate it or knows of a fix like an updated version of UI_starter
Such as the one at the bottom of this link: http://www.zbrushcentral.com/showthr…leshooting-FAQ…I’d appreciate it
I’d like to get GoZ going with my new install of 4R4. When I go to the Download Center under ZBrush Plugins, I see an option to display plugins for ZBrush 4R3, but not one yet for 4R4. Okay, so looking under the 4R3 plugins I see the link to download the GoZ 4R3 plugin, with a release date of Jan 4, 2012. But when I click the link for that download, the file that is displayed to download is showing as ‘GoZ_4R2_WIN_4_jan_2011.zip’.
(1) Is this really the very latest GoZ plugin file available?
(2) If so, I assume this is the one I ought to then install for use with 4R4 anyway?
(3) Will this then be compatible with the latest service pack of Modo 601?
Thanks,
Dan
I would also like to add that I am disappointed with the removal of the Reference View options. The new grid system does not appear to have all the same functionality, and until I can figure out how to get the old reference views back, I’m at a standstill on a lot of projects.
Could this please be put back in? If it’s not broken, why prune it out? Or is it just moved out of the Texture palette? If so, where is it? :c
I have old version of Zbrush 4.0 which I bought last year ago then later upgraded it to 4R2 and 4R3 for free. I already installed a new version Zbrush 4R4 into my computer under Window 7 Professional. All of 4.0, 4R2, 4Rb and 4R3 are everything include the new features of 4R4 version but I’m not sure if I should keep old versions to stay with 4R4 or not. I have a question for you.
Should I uninstall all old versions if necessary and keep 4R4?
OK … Thanks!
Same here, and only given 2 days to download…which I cannot do (tried everything suggested )
AL
Hey Aurick am not sure what you mean saying that symmetry buttons have never worked as custom UI. I use that all the time from Zbrush 3 times. Well till now … 4r4 is replacing it with some other buttons when i switch to another tool. Just for case we missunderstood each other take a look at picture… on the top is my custom UI with symetry buttons which i use for years, On the bottom is what happen after i switch to other tool. I can say its really annoying mistake …hope pixo fill fix it soon.
Thx
I am now getting the 404 not found error on chrome and firefox and it tells me I only have 2 days left.
What gives? anyone?
I’ve just found the same error. I have submitted a support ticket and hope the Pixologic team can resolve the problem.
hello ZB and ZB4R4 useres - i have constant crashes when working with surface > noise
have used the z-plugin>updater and patch 01 was installed - same issue.
sometime ZB4R4 crashes when i click “noise” - sometimes when click “ok” in noise and if i come that far and want to “edit noise” - ZB4R4 crashes then…
does anyone else have that problem?
not sure if i have a local memory problem somewhere on the 32gb ram - or it is a ZB4R4 bug.
Would be great if someone could confirm this as a bug on Win7 64bit or not.
Have tried to run the Memory Stress test on within ZB4R4 - but it seems to fail - not sure if ZB4R4 failed or my RAM.
successfully ran Microsoft Diagnostics Memory tool - and no issues found.
Have posted a support ticket regarding this issue
Have stress ZB4R4 with heavy Dynamesh and different hardcore workload -= but no issues else except for this NOISE crashes
just tried to download 4R4 for another Win7 pc - but get the same 404 error after generating the download link.
ZB4R3 noise works fine.
best regards from europe
Mads
despite that - great features in 4R4 …
