Insert Multi Mesh Repository
thanks for the shoe lacets , very usefull.
CLICK HERE TO DOWNLOAD BRUSH
Hey guys here’s my first little contribution… It’s been a little tough to figure out how to get the TriPart brushes to weld properly.
All the spirals are separate meshes so with autogroups they can be selected, removed, and edited as you like.
Insert_Spiral Leaf.zip (11.9 KB)Insert_Spiral Leaf.zip (11.9 KB)
thank’s :slight_smile: thank’s :)thank’s :)thank’s :slight_smile:
WOW!
What a fantastic thread! Thank you guys for the great brushes and the time you spend for create this very useful stuff :slight_smile:
Yes sure it is a fantastic thread and a great idea to share these materials, but , unfortunately, it is impossible to use the most of the parts of the files IMM when you work like me on a Mac version.The brushes doesn’t work, the version of Windows having had an update, maybe it is the problem.
JB
I’m using a Mac and I can use all of them. You should run the ZUpgrader file in your ZBrush root folder and see if you still have to get the update.
The autoupdate plugin inside ZBrush didn’t work for me, but executing the file directly did.
Thx a lot Hendrik, I never paid attention at this upgrader that is really cool
Have you tried my IMM Chains Brush? That was created on a Mac.
so far for all the cool stuff posted here. I am overwehelmed! As soon as i got something done ill share as well.
Endemo
Yes its works perfectly, thx a lot for this chain
ill be sculpting a shoe so i made this to make it easier ssbrs.jpgitll be for free download here zd3ds.yolasite.com/zbrush.php
Picatinny Trail Brush, Inspired by Joseph Drust new tutorial set.
Stroke > Curbe > Asline recommendedPicatinnyTrail.ZBP.zip (319 KB)picatinny.jpg
Oh man this looks great! I’m going to try not to blatantly use these for all my rock needs but how would you like attribution if I do?
Brilliant thread.
Here’s my contribution:
Bullets and Shells
You’ve got 9 mm, 45 mm and hollow point, and their shells to go along with them. I tried to keep the poly count as low as possible. Just use “M” to open the menu, select and then use Move and Rotate to place them as needed.
Bullets and Shells.zip (256 KB)Bullets and Shells.zip (256 KB)
Thank you all for the contributions.
nickz I really love this IMM Brush:) Thank You for creating them. here’s a beginning of a scene I’m using them on with the fractal cave.
Bas these are great IMM Brushes - I like the Celtic designs and they work wonderfully.
Here’s something I did with them - The Celtic Mask
CELTIC MASK8a.jpg-
Thank you everyone!!
4.4 is normal release of zbrush 4 R4, 4.42 is the floating license version. I’m guessing he made these hoses at work where he has floating license version. I’ve had this issue when trying to take my work home. I hope that clarifies but I don’t have a solution :frowning:
