Gears of War 3 - Environment Art
These were the exploded versions of the ticker clamps
A couple of people asked about lowpolys and how much things were built for modular support.
These 2 sets of lowpoly production shots were built out of the concrete railing set hipoly below.
Due to everything being built first on the grid in max before I import to Zbrush I know that everything will slot together easily once I export back to max to process the hi to the low. I tend to think in terms of element based designs. Most designs are just a combination of elements merged together, much like most forms are a combination of the basic primitive shapes such as a cube , sphere, triangle, rectangle etc.
So in the case of this piece, there are 4 pillar elements, 2 with minor damage, one with heavy damage and 1 thats blown to pieces.
There are 4 block elements, the top and the bottom pieces, each has a regular minor damaged section and a blown to pieces version.
The last element is the lionhead block piece that interupts the other forms and is a good start and stop piece to cap the design.
I make sure everything that between each section there are panel like extrudes so that when I make duplicates and stack them beside each other to extend or shorten the design, I can use that crease spot to hide the seam. Basically I model an intentional seam where I know there will be a seam after I stitch 2 pieces together. Its the same principle as metal panels stacked together. It’s just a cheap trick to draw peoples eyes away from where I am cheating by repeating the design, it works really well though and when things repeat too much and look boring, ingame the level designers can vertex paint on top to create variety.
You can get an impression of what I’m doing in the texture above now I hope?
[HR][/HR]Some Rubble Blocks. I made a few of these for combining to create other meshs. They are always useful to have lying around and very relaxing to make.
you make it look so natural, just as a stone/pillar would be damaged in the real world. Very cool:+1:
Would be great! Thanks for sharing!
Very awesome. Thanks for posting.
Hey Folks, thanks as always for the comments… I have a bit more time tonight to get into some proper answers, sorry this took so long. I have a tendency to take on too many tasks at once and get overloaded.
Demonfetus - I think imitating my method of showing small modular pieces would probably work against you. When I initially started trying to push this way of working here I was shut down pretty aggressively at first and over time I gradually made my case for working as I do. It took about 4 years for this to be officially recognized and accepted as useful. People are more impressed by big fancy levels, only other artists/ designers can appreciate the cleverness behind them so you have to make sure you show them some pretties that anyone can understand. Oscar Wilde said that beauty is the only true genius because is the only once that anyone can appreciate or recognize.
So make cool pieces and show hipoly / lowpoly /unwrap … but know that its only the designers and content creation folks that will understand that part. The big level shots with the pimped out lighting and all the pieces put together is what sells you to the whole team.
The hipoly is the easy part, anyone can make a pretty hipoly piece of art but after that is done with the real work begins; sorry but thats the deal. The lowpoly process is what decides whether that pretty hipoly thing will look good ingame or be a piece of crap, it decides whether it will be hi res and efficient or low res and a resource hog. Will you have a good pivot point that the level designers can use to easily manipulate the asset? Will you pay enough attention to a global scale across a set of assets to make them convincing and realistic in relation to the player characters scale? Are your pieces well thought enough to be robust enough for you to make variants from the base mesh or take requests?
These are the real skills that I look for. Anyone can make art, but can a person make art that is of use in-game is the difference between an artist and a game artist.
I generally decimate the hell out of my meshs in zbrush , take em back to max and clean them up , symmetry modify and unwrap. Sometimes I just build the lowpoly fresh in max, often I have it built beforehand as I generally build a lot of my designs in max before taking them into zbrush to weather them.
Those cool trash pieces were done in Gears1 by Josh Jay and they proved how much those pieces that people look down upon actually add to a game, much like foliage. The rubble stuff pre Gears3 was mostly Danny Rodriguez.
Nicholas - Thanks. Mostly I just reuse my original hipoly art once I optimize it down. I will try to explain in detail how I did a couple of pieces later though to show some processing tricks as thats really where the magic happens or things go wrong.
Okimoki - I’m generally too embarassed to show a video tutorial. It would only expose how pitiful and lacking, slow and awkward my workflow is. Maybe its just imposter syndrome talking, but there really isn’t anything impressive to share. Looking at the video tutorials others here are doing totally puts me in the shade. All I do differently than most folks I see here is plan ahead; I mean really far ahead. I can’t really demonstrate that distinction in a video.
Mattj324 - I will try to scrounge through my WIP folders and find some stuff to demonstrate my starting point to end point.
adi3199 - Sometimes we have to ditch and run and leave the weatheration to the texture guys when we run out of time. Tight deadlines rule the day.
Kaleden - Pretty much all of them.
logansan25 - Mostly max for hard body metal stuff and zbrush decimation for organic stuff like rocks.
New stuff - Below is a lampost I did and the lowpoly wires for it ( generally, every piece I posted here has a 2nd image below the first that is the lowpoly mesh, I just didn’t overlay the wires.
Most designs can support a few variants , even a lampost. I try to think about this stuff up front. 10 mins extra spent thinking trumps 10 hours building often.
Below are the first pieces I did for Gears3 while I was still in crunch on Gears2 and going kind of mad because I hadn’t done any hipoly in so long.
One of the main crits the level designers had of my work in Gears2 was that I made too many designs that had uncapped tops or bottoms or didn’t have custom designs for those areas if they were capped. My reasoning for this choice was optimization but it worked the other way because so many of Gears assets are thrown in askew… and this exposed the uncapped holes which then required the use of an additional mesh to hide them. So that worked out badly and I set out to address that with this piece and also to make a super modular generic concrete wall support as there was so many of them in Gears that I wanted to try and consolidate a variety into one texture.
The above design was composed of the elements below. I built things this way so I could recombine them in different ways when I did the lowpolys.
Below you can see the standard version with all the pieces in the default configuration.
And now the variant elements on their own
Heres some lows for the Spirestrut piece I showed the hipoly of.
Some variants
Some more
Below are some Hipoly shots of the Bustram. Lee Perry came up with the idea for using an upturned bus with a pulley system like a skilift in the Char level which was just brilliant.
It went through many revisions for gameplay reasons though and building it and rebuilding it nearly broke me over the course of almost 2 months to get it ingame.
Oh yeah, I almost forgot. At some point during the design I thought it would be cool to hook up a lawnmower starter cord tied to an engine that provided the power to turn the pulley system. I didn’t work out exactly as intended but it got in there and was a lot of fun :slight_smile:
I’ll try to dig up some shots of the final lowpoly meshs next time
Love all of these, great stuff, keep posting moar!
Hi Kevin
YOur environment stuff is awesoem. Just wondering if you could share with us how you create tileable textures. I was wondering if it is good practice to first create a tileable diffuse texture place it on a and then try to create you normal map in zbrush using the diffuse as a guide. Iam trying to use this method but im not sure how to achieve it in zbrush because i cant seem to be able to offset my normal map on the plane to fix the tiling. Any advice would in trying to make good tileable normal maps would great.
Cheers Luke
Awesome! I love it!
Thanks for the generous breakdowns! Brilliant work.
Is there enviroment art for Gears of War: Judgment?
