Thanks very much. Great materials.
great materials …
But is it possible to have those materials in 3ds max too ?! i mean for Mental ray ?!
nice sketch mat, but you have to modify it some to actually look like a sketch, it seems to come with a texture applied that fills the object with some sort of noise.
a huge thankyou for the materials!..i use a variety of them while sculpting now. You can see a variation of one of them here
Thankyou so much once again for sharing!
Looks like the material links are gone. Can anyone re-up these somewhere?
Found the sketch material in the Material Downloads library section. Still searching for his skeleton matcaps…
If you give me your email address I’ll send them to you
These links don’t work anymore. Does anyone have access, or links to these zip files?
You will find that the materials posted here are accessible through this method:
http://www.pixologic.com/zbrush/downloadcenter/library/
Then under MATCAP SKIN.
Then shaders 13-19
I believe the others are there also. Its worth having a good route around to see all the amazing shaders available there.
Hey guys,
Does anyone have an issue with these materials where they show up with white streaky lines all over the model? It’s been happening to me since I think 3.5, and it’s driving me nuts, because I love these materials. I’m trying to render out a skull study I did and I’d love nothing more than to use one of the Arran Lewis bone materials on it, but none of them work for me
you can get rid of it very easily. Select the material, go to Material -> Modifiers -> S3 and then turn Outer Intensity down to about 27 or something. that should do it.
Does anyone know if you can turn noise into actual bump like in the material preview?
You are a godsend. That worked PERFECTLY! Thank you so much!
no problem, man.
I was wondering if the sketch material (1st page, 2nd picture with spine) is still available somewhere.
Hey Hendrick,
I just found the material you were asking about. It’s also in the official library here. It’s in the “Matcap Effects” section, material 16. Hope that helps!
thanks a lot, man! favor returned
The links still don’t work. But the files look great. Any way I could get an updated link?
Hey everybody,
Could somebody re-upload the materials? It seems the link is dead
Thanks!
Andy
You can find most of these on the MatCap Lib under the “Skin” section. http://pixologic.com/zbrush/downloadcenter/library/
